Thread: Go Pro Camera
Created on: 07/31/14 07:44 PM
tclogston
tclogston's Gravatar
Go Pro Camera
07/31/14 7:44 PM
Where are people mounting go pro cameras on the ZX14....I don't want to mount it on my helmet so looking for an alternative....thanks,
Troy
Troy
2014 ZX 14r Yosh Carbon R77 slip-ons, PCV, Pazzo levers, Galfer stainless brake and clutch lines, Puig tinted screen, Vortex Rear Sets, Vortex black gas cap, PSR passenger pegs, Full HID light kit, Hotbodies undertail, Smoked taillight and front and rear turnsignals, Michelin Power Sports, Vortex Black Anodized Sprocket., Traxxion Dynamics front forks, Penske rear shock, Rizoma fluid reservoirs, carbon fiber rear hugger and chain guard.
KoflaOlivieri's Gravatar
RE: Go Pro Camera
07/31/14 8:12 PM
There are a few pics on THIS THREAD.
* Last updated by: KoflaOlivieri on 7/31/2014 @ 8:13 PM *
fatsix
fatsix's Gravatar
RE: Go Pro Camera
08/01/14 6:38 AM
Moto D mount
Can be used to mount anything.
2012 ZX14R CSB
RE: Go Pro Camera
08/01/14 7:37 AM
I like the tail (TW he S).
The side is always good and you can even get the suction cup to mount to the top fairing looking back at you.
* Last updated by: Rook on 9/3/2014 @ 12:58 PM *
RE: Go Pro Camera
08/01/14 8:18 AM
* Last updated by: Grn14 on 8/1/2014 @ 8:21 AM *
RE: Go Pro Camera
08/01/14 6:23 PM
RE: Go Pro Camera
08/01/14 9:10 PM
I 'revised' mine(naturally,can't leave ANYTHING aloneLOL!)....bought the 'frame' mount deal....cut the mount tabs off the stock clear cam housing...epoxied em to the frame mount....really cuts down on the bulk of the stock housing.Not good however in the rain...but I don't do that anyway.(If it did rain...the cam would be in my pocket right quick;)
I think the 'weight' reduction does help with the vid quality...less enertia when hitting rough spots and such.
I know my pics show the standard housing...but it's been replaced a while back.Can easily mount it now on the helmet(chin)without the added weight and bulkiness when leaning forward.
* Last updated by: Grn14 on 8/1/2014 @ 9:12 PM *
tclogston
RE: Go Pro Camera
09/03/14 4:12 PM
Kevin,
Do the 3m mounts leave residue or take paint off of fairings? Curious and not willing to find out on my own..:)
Thanks,
Troy
Troy
RE: Go Pro Camera
09/03/14 6:28 PM
I'm not Kevin...but I can say..NO..they won't damage paint when removing...just don't try to YANK em off...gotta pull (lift)steady on one corner to get it to start to release...then stay with it.Hairdryer before removing will help also.Saving the red backing paper can be reused when the mount is off the bike and being set aside....they can be reused several times before the stickyback weakens.
* Last updated by: Grn14 on 9/3/2014 @ 6:32 PM *
johnnypoc
johnnypoc's Gravatar
RE: Go Pro Camera
10/15/14 5:10 AM
I had mine mounted to the windscreen, worked well until I got into a race with a busa and it decided to let go.
RE: Go Pro Camera
10/15/14 7:49 AM
ohSH!T! I hope it was tethered?
I had mine stuck to the top fairing near the mirror mount and no problems. Didn't go over 130 though.
RE: Go Pro Camera
10/21/14 1:41 AM
So what is the best mount for high speed?
RE: Go Pro Camera
10/21/14 2:10 AM
I've used the suction mount...AND the adhesive ones.They both work fine.With that adhesive one...you have to let it stay stuck on there for several hours initially.Push it on there and hold it for a minute or so..firmly against the surface.After that...let er sit.I've had mine up to 190...suction and adhesive both at different times...on the screen...on the nose...on the side fairing.Never came loose.
You have to consider the wind force and the arm length you're using.The cam will add some mass to the arm(s)...so I normally if attaching to the side with the suction mount reinforce the arm to the fairing(side covers tines)with some electrical tape..that works well just in case.The shorter the arm attachment...the better off...regardless of where you're mounting it.And that suction cup deal....it needs to be on a surface free of decal lines...or anything that might break the seal under the edge there.Mildly convex fairing areas work well.The adhesive mounts...you can put them virtually anywhere so long as the pad is fully contacting the surface.I wouldn't recommend applying those over any decals or custom flames or anything.That 3m adhesive sticks like a SOB....gotta peel that mount off REAL SLOW and carefully.Steady pressure starting at one corner and getting that lifted enough to get you finger under the mount to continue pulling away.SLOWLY!You can always use a hair dryer to soften up the stickyback...just don't melt yer bikeLOL!!!
* Last updated by: Grn14 on 10/21/2014 @ 2:23 AM *
